Post by Jeff - jthspace on May 23, 2023 16:05:48 GMT
Saw another NA with one and thought it looked good, not normally "my thing" chrome, but...... 10 minute job. Before During After
Post by RS on May 23, 2023 16:19:55 GMT
Had one of those on my NB, it's probably still on it.
Post by Jeff - jthspace on May 23, 2023 16:21:26 GMT
Instructions say don't use metal polish on it, just soap and water and a good wax, which I've done.
Post by mxdave on May 23, 2023 16:24:57 GMT
I had one of those on my NA it didn’t last long before it started to corrode and looked awful. Changed back to the original. It’s still in my garage somewhere.
Post by RS on May 23, 2023 16:25:58 GMT
Instructions say don't use metal polish on it, just soap and water and a good wax, which I've done. I've got one kicking around that has been polished with metal polish, it's not pretty any more, it's a bit patchy, could do with re-chroming, but would probably cost more than the cap was worth.
Post by Jeff - jthspace on May 23, 2023 16:31:38 GMT
They do warn that it's chrome on polished alloy; assume as chrome is porous and water will get through and lift, it will deteriorate; so a good wax will help keep it waterproof. Same reason chrome on steel will rust through and lift unless properly plated with nickel prior to chroming.
Post by gonzo on May 23, 2023 17:06:41 GMT
Same as everybody else, they look good for a while but start pitting eventually. I had one for a while then put the original back on
Post by Roadie on May 23, 2023 18:27:28 GMT
Looks good. I do like them. However, don't forget to take the original when you have the car resprayed next year. That way if the chrome does go pointed lady bits up you have a shiny red one to put back.
Post by Jeff - jthspace on May 23, 2023 18:43:22 GMT
Looks good. I do like them. However, don't forget to take the original when you have the car resprayed next year. That way if the chrome does go pointed lady bits up you have a shiny red one to put back. Good thinking.....
Post by goonz on May 24, 2023 7:03:54 GMT
Had one of those on my NB, it's probably still on it. Still got mine on my NB
Post by goonz on May 24, 2023 7:04:04 GMT
Looks good Jeff
Post by mondrian on May 24, 2023 7:04:50 GMT
I think you won mini 10HP
Post by swannie on May 25, 2023 7:20:07 GMT
Looks very nice Jeff, it’s something that I quite fancy getting too 👏🏻👏🏻😎
