Post by Jeff - jthspace on Jul 24, 2021 12:58:18 GMT
If you need an internal 12v tap then these two fuse positions give you ignition controlled or always-on. Use a fuse doubler to tap the power  If you need an under-the-bonnet ignition controlled supply, this fuse position is available. It's on the side as this is what you will see when you remove the fuse cover.
