Post by Roadie on Aug 15, 2021 19:33:56 GMT
Mazda MX-5 Mk4 ND Miata 2015 - 2020 Soft Top Acrylic Wind Deflector 2015 - 2020 models, Soft top. Not suitable for RF retractable fastback models Available in Clear and Tinted Grey £60 including UK delivery. PM me for payment details and with any questions. Designed as a replacement for the plastic mesh wind deflector fitted as standard Around 25mm taller than the original part so should be a little more effective but without access to a wind tunnel I’m not claiming any improvement with regard to this. Any taller than this would make it difficult to open and close the roof from inside the car. I have no problems doing this with the prototype fitted to my own car. Unlike some similar products my kit does not require any drilling or screwing into the vehicle. Bottom mounts clip in and side supporting guides are attached using genuine 3M brand tape. 5mm thick clear acrylic sheet which is laser cut to my own design which can be easily cleaned using just soap and water. Acrylic will not yellow from exposure to UV rays as polycarbonate is prone to do. What this product does do is provide much better visibility in the rear view mirror. Even with the roof up I can see the bulge of the high level brake light in the mirror. With the roof down the view is much improved. Looks good too! Fitting is easy following the instructions supplied. The only tool required is a screwdriver to fit the two screws holding the screen into the mounts.
