Post by Jeff - jthspace on Aug 28, 2021 14:10:03 GMT
Bought a new snow foam applicator as my plastic one cracked, it wasn't much cop anyway as it gave a very watery foam. I bought one with brass fittings and a bigger (1 ltr) bottle.
I also bought AutoGlym Polar Blast snow foam.
Combination of both gave a very satisfying layer of long lasting foam on the Citroën (hadn't run off even after 15 minutes) and lasted about 5 minutes on the ND but that is ceramic coated so is very slippery. Saying that, it still had a good covering.
I did both cars with one and a half fills of the 1 litre bottle, 10% foam to 90% water and on minimum mix setting on the mixer.
Very pleased with the result.
Post by fivedriver on Aug 28, 2021 17:43:41 GMT
Snow foam seems to be quite popular at present. I gather it is designed to loosen surface contamination before a contact wash? Once you've applied the snow foam and let it sit you would then power wash the remnants off before going over the car with buckets and wash mitts/sponges?
Post by RS on Aug 28, 2021 17:53:22 GMT
Snow foam seems to be quite popular at present. I gather it is designed to loosen surface contamination before a contact wash? Once you've applied the snow foam and let it sit you would then power wash the remnants off before going over the car with buckets and wash mitts/sponges? Yep, spot on Guy...
Post by fivedriver on Aug 28, 2021 18:01:03 GMT
Thanks RS.
I do like the idea of treating my cars but have concerns over TOG's bonnet louvres letting too many suds and too much moisture into the engine bay. 🤔
Are there any pressure washers that work purely on a reservoir or do all need running water? The only tap I could use is a mixer and has a weird connection. 😏
Post by RS on Aug 28, 2021 18:15:19 GMT
Thanks RS. I do like the idea of treating my cars but have concerns over TOG's bonnet louvres letting too many suds and too much moisture into the engine bay. 🤔 Are there any pressure washers that work purely on a reservoir or do all need running water? The only tap I could use is a mixer and has a weird connection. 😏 Is this the sort of thing you're thinking of ?.... Pressure cleaner
Post by fivedriver on Aug 28, 2021 18:47:51 GMT
Now that looks pretty good RS. With your experience, what are your thoughts on that one?
Post by RS on Aug 28, 2021 19:34:54 GMT
To be honest, I've never used one but it looks an ideal solution to not having a mains pressure hose available, just a bit of a pain having to walk backwards and forwards with buckets of water.
