Post by Jeff - jthspace on Sept 8, 2021 14:36:56 GMT
These are a direct replacement for NA and Eunos headlights and give you very bright LED main and dipped lights.nTheybare CE marked and LEGAL in the UK. They are NOT LED bulbs, which will fail an MOT test, but REPLACEMENT sealed units that are acceptable. They also include LED ring sidelight which can also be wired as switchback indicators if required. About this item √ THE NEWEST UNIQUE DESIGN, DIY YOUR CARS: Enhance The Look And Performance Of Your car With The Next Generation Of Led Lighting. The Headlight Kit Comes With Everything You Need To Switch To The Completely Modern And Powerful Led Lighting System
√ HIGH PERFORMANCE Hi/Lo BEAM, INCREASED SAFETY: Brighter, But Softer Light(Closer To Daylight), Efficiently Relieve Driving Fatigue. Complex Reflector Design Can Improve Overall Visibility While Project Light During Long Distance, Helping Drivers Receive Better Views And Road Reflections
√ EASY PLUG AND PLAY INSTALLATION, SAVING YOUR TIME: Comes With Standard 3 Blade Connection, H4 Led Driver And Wiring Adapter, Making Installation Is Quick And Easy. Just Connect The Light To The Factory Headlamp Wiring. I have had a set of these fitted to Daisy for 2 years and no issue with MOT'S. Gives a fantastic light when driving at night, no more trying to see what's 50 ft ahead in a dark country road. £50 posted UK mainland or £40 if you pick them up at Edenbridge next weekend.
