Post by fivedriver on Mar 29, 2022 13:34:45 GMT
Hi everyone, May I share a project that's ongoing please? Ever since I bought TOG i have dreamt of giving her twin front lights. Years ago I mocked up an idea in photoshop to see how she'd look if I replaced the factory oval lights.  My plan had been to fit seperate light lenses into the existing lights. My main roadblock has been finding suitably sized lights. Back in the day a french company called Morette produced light clusters similar to this for many car models including the NB. They are however, very rare now and quite expensive. Fortunately I found a set. A kind gentleman by the title of MazdaMender allowed me to purchase a set he had going spare. One area where my design differs from the Morette lights is the position of the indicators. Whereas I have positioned TOG's indicators in her bumper, Morette put the indicators in their cluster.  This means that I am unecessarily doubling up on indicators. My solution is to use the indicator opening as a fresh air inlet into the engine bay.  Using a selection of items cobbled together from Demon Tweaks and Car Builder solutions I think I can make it work.   Here's another ps mockup of how she could look soon.  These units are wired slightly differently so not a direct "plug and play" replacement which means, I may be drawing on the collective information bank to help me complete the project. Cheers, Guy
Post by Roadie on Mar 29, 2022 20:01:36 GMT
That's going to look very nice. Are the existing headlights combined dip and main beam three pin H4 bulbs? If so probably best to make up a pair of adapters to connect to the new blingatronic units. Unusually for this forum I'm not too far away to offer assistance. Let me know if you need anything.
Post by Jeff - jthspace on Mar 29, 2022 21:26:56 GMT
Impressed by the lights and the photoshop skills! Wish I could use PS like that.
They are separate low beam / high beam bulbs, low beam being what I call “eyeball” shape and the high beam looks like an H1 or H3 from a zoom onto a photo. Not exactly plug and play but TOG would expect nothing different!
Post by fivedriver on Mar 30, 2022 9:09:58 GMT
That's going to look very nice. Are the existing headlights combined dip and main beam three pin H4 bulbs? If so probably best to make up a pair of adapters to connect to the new blingatronic units. Unusually for this forum I'm not too far away to offer assistance. Let me know if you need anything. Hi Roadie thanks for offering to help, that's very much appreciated 👍 The lights came with a modified loom so with a bit of luck they might be relatively straightforward to connect. (They'll need to be for me to cope with the task 😉)
Post by mondrian on Mar 30, 2022 11:22:11 GMT
Post by fivedriver on Apr 1, 2022 14:30:53 GMT
Here we go then. Before.....  After...   I'm very pleased with the results. A big thankyou goes to Jeff (Jeff-jthspace), Ian (RS) and Paul(Roadie) for their help and guidance. Couldn't have done it without you guys,
Post by Jeff - jthspace on Apr 1, 2022 14:39:18 GMT
What a difference! Looking very individual, very nice. 👏
Post by Roadie on Apr 1, 2022 14:54:02 GMT
Wow. That looks amazing. The whole car looks lower, wider and more balanced. Love it, love it, love it. With the separate sidelights and indicators it looks like it should always have been that way. I think you once said you were going for the 'cafe racer' look. Nailed it.
Post by Jeff - jthspace on Apr 1, 2022 15:10:04 GMT
One for Mondrian to admire  One for your Avatar (maybe)
Post by RS on Apr 1, 2022 15:32:59 GMT
Well done Guy, it's totally transformed the look of your car, and you've achieved the look you were after.
Post by fivedriver on May 14, 2022 16:17:34 GMT
Hi folks. I'm sending out an SOS. I appear to have developed a peculiar problem. Well, not me exactly. TOG has developed a peculiar problem. Her nearside headlight is not illuminating anymore. I swapped bulbs from nearside to offside and it still lit so I think that rules out the bulb. Same story with the relays. Swapped and the offside illuminated but not the nearside. The full beam lights up on both sides. Originally I had this issue which was solved by turning the headlight plug through 180° but not this time sadly. Another oddity is that I've lost the blue full beam warning lamp on the dash. Are there things related? Could it simply be a fuse? I've looked under the bonnet and the 40amp fuse looks to be intact as is the 20amp inline fuse wired into the new lights loom. Is there another fuse I should be looking for?
Any help with this puzzle is much appreciated. Cheers Guy.
Post by RS on May 14, 2022 18:28:32 GMT
Bit of an odd one that....
There are 2 fuses, one, for the left hand light and one for the right, I'd check them first (remove the fuse and check the continuity with a meter).
Then I'd check for a live feed at the plug for the bulb, from then on, I'd start checking the wiring back through to the original vehicle wiring.
If possible, unplug the whole of the new lights and plug in a couple of the old bulbs to the OE wiring to see if it all works properly as it did before
Sorry, I can't be more of a help, it's a shame that you're some distance away from me as I'd be round to help you out !
Post by fivedriver on May 14, 2022 19:22:39 GMT
Thanks for the help RS. I had a look under the righr hand side of the dashboard and found a fuse box. Fuses #19 & #20 seem to be for the headlights. They are 15amp and blue in colour but both appear to be visually intact 🤔 Perhaps I'll invest in a multi-meter and try checking the wiring. Using the old lamp unit to check the feed up to the new loom is a good call and may narrow down my search a bit. Thanks for the suggestion. 👍 Hard to fathom how these things work one minute and not the next 😳 Ah, the joys of an older, modified car 😄
