Post by mxdave on Mar 31, 2023 16:29:37 GMT
Yes I know what you're saying. I know I do get this problem on a long run if you're using your phone for Google maps etc. If I need to charge while on a long run I will just unplug the wireless box and plug my phone straight into the CarPlay USB as this now has a higher output following the upgrade. I also have a 2xUSB adapter that can go in the 12V accessory socket for Ann to charge her phone, it always needs charging
Post by mxdave on Apr 8, 2023 15:41:08 GMT
Decided I’d hide the wireless dongle away out of sight. So I removed the trim and seat belt warning/heated seat buttons and filed a small slot in the top of the USB hub bit. Fed the cable through and sat the little box inside the dash and then put it all back together. I will leave the cable from the dongle plugged in until I need to plug the phone in to keep the charge like if I’m using it on a long run and then I’ll just unplug the dongle and plug my phone cable in.
Post by Jeff - jthspace on Apr 8, 2023 16:03:23 GMT
Had been thinking something similar, may just do the same now.
