Post by RS on Apr 8, 2023 15:30:05 GMT
Well you learn something new everyday.....I never realised that there was a sort of cabin air filter type thing fitted to an ND. Shows the fitting of a mesh grille over the intake to stop bits of leaves being sucked in and to keep Rodents out ! This video also shows an updated cabin filter being fitted.. Link to the filter kit
Post by mxdave on Apr 8, 2023 15:57:05 GMT
Wow, that’s a lot of work to change that filter. Does this get done on a full Mazda service?
Ours will be on the other side of the car though, won’t it 😆
Post by Jeff - jthspace on Apr 8, 2023 16:00:22 GMT
Two things
1. Nice to see bonnet lifters fitted
2. Would like to see a video of someone getting past the steering column on a RHD to change the filter
Await RS Garages LLC video of same . . . .
Post by Jeff - jthspace on Apr 8, 2023 16:01:34 GMT
Wow, that’s a lot of work to change that filter. Does this get done on a full Mazda service? Ours will be on the other side of the car though, won’t it 😆 If its the same on RHD, think a Henry vac tube down from outside may be the easiest option.
Post by RS on Apr 8, 2023 16:18:09 GMT
Does this get done on a full Mazda service? Wouldn't have thought they'd go to all that trouble, if they did it would cost a fortune in labour.
Post by RS on Apr 8, 2023 16:19:38 GMT
Ours will be on the other side of the car though, won’t it 😆 Not 100% sure but I'd guess it'll be on the nearside. The reason NDs don't have a glovebox, is the space is taken up by the AC / heater box and fan ducting.
Post by RS on Apr 8, 2023 16:20:38 GMT
Await RS Garages LLC video of same . . . . Maybe one day......
Post by RS on Apr 8, 2023 19:17:43 GMT
Ours will be on the other side of the car though, won’t it 😆 Not 100% sure but I'd guess it'll be on the nearside. Yep, it's on the nearside....
Post by mxdave on Apr 8, 2023 20:56:03 GMT
Have you been out to the garage this evening and stripped the dashboard out to check??
Post by RS on Apr 9, 2023 9:19:09 GMT
Have you been out to the garage this evening and stripped the dashboard out to check?? Yep, especially for you....
Post by mxdave on Apr 9, 2023 10:00:03 GMT
Post by boycie on Apr 10, 2023 7:59:57 GMT
Does it work with the hood down
Post by RS on Apr 10, 2023 9:20:44 GMT
Does it work with the hood down Only by 0.5%......
